JRMunn's avatar
JRMunn
Heater Motor Squeal
My heater fan motor is starting to squeal, despite the life-time sealed bearing in it. Does anyone have experience in changing a heater fan motor? I tried searching on "heater motor" without success. The rig is a 2004 Sunnybrook Titan 5th wheel and the heater is a 30,000 BTU Atwood Hydroflame model 8531. I expect that this is a fairly common heater across 5th wheel and trailer brands. I looked inside, because it appeared that the job would be straight forward from the parts diagram, and I did manage to pull off and then put back the fan chamber front plate. But the motor is inside the main fan and its shaft has fans both inside and outside of the burner chamber. Space is very tight, there are lots of wires, and I couldn't figure out how to get to the motor screws. Does anyone know if or how this might be fixed? So far, the squeal only starts when air temperature in the fan box is below about 57 deg. F.
JRMunn
