JIMNLIN
Oct 12, 2022Explorer III
Interesting. Thanks. These are on my gooseneck trailer. GVWR =16k but it came with 12 ply tires. Not sure what psi the rims are rated for but I ran 80psi in the old tires.
One of my non rv trailers is a 38' triaxle stock trailer with 7k axles. I had the trailer mfg derate its gvwr from 21k to 16K for tax and registration purposes. It came with ST235/85 16 G @4400 lb capacity cheap brand ST tires ( Hi Run brand ??)
I was aware they had a bad rep doing that type work so I had 6 Sailun S637 ST235/80-16 load G at 4080 lbs capacity ready when my trailer dealer called and said your trailers in. He did the change out for free.
Sold the maypops on CL for more than the trailer mfg sold them for which helped pay most of the cost of those commercial grade all steel carcass 16" Sailun S637.
I keep tires on all my commercial trailers and rv trailers tires at max sidewall 24/7.
Heavy tires rob horse power as any racer/commercial hauler knows. However in my hauling business those heavy tires at max sidewall pressures are worth the extra weight in long term service and higher miles of service. A RV trailer are no different.
About Fifth Wheel Group
