ItsyRV
Feb 22, 2021Explorer
I use the HD FasTen Blocks for Dual Wheels. They are larger than the standard ones so they can spread out the load on the ground. I have used them as a emergency frame jack stand when fixing my RV on the side of the road. They are super easy to go from a block to a ramp. I have used them for traction boards when needing to get out of snow, mud or sand. When not being used for leveling, they make a great campsite ottoman. You can even use them as a chocks.
The down side is they have been known to fracture when placed on very uneven ground and weight has been applied to a spot over a void. I have also seen them crack when larger heavy RV's use them as traction boards. Because of their larger size, you have a higher chance of having voids under them when used for static purposes. But likewise, on soft ground, the large size means more stability (honeycomb design) as they form into the soft material making their own level surface.
About Fifth Wheel Group
