nayther
Feb 23, 2021Explorer
deltabravo wrote:joe blow wrote:
What are some proven recommendations that some of you have used with success on the same weight trailer?
Wood blocks. 2x8
I built some using 2x cross stacked, capped both sides with 1/2" plywood. The plywood won't split, just screwed them together. Makes about a 4" tall block. I cut them to the same size as the lego blocks so they all stack in the same location.
I also have an Anderson ramp type leveler, need a second. It works really well if the ground is gravel as it won't slide. We boondock in the desert most of the time and I try to get reasonably level before deploying auto level. Often have to put blocks under rear jacks as I've raised them up all the way for ground clearance.
Another is to get ahold of scraps from a construction site using composites, like OSB and Glulam, those products are pressed together and are super strong.
About Fifth Wheel Group
