CKNSLS wrote:
To the OP-
You will never have anyone on this forum OK a half-ton for ANY TOWING NEEDS.
File it under "it's not gonna happen!"
Really guess I missed that Although no we would not go any heavier we are just fine and have been in the Ozarks several times and 8hrs straight through. If you truly want a 1/2 ton do your home work make the specs fit both for truck and f'ver. All I can say is our ECO boost does an excellent job. Yes it is max tow haul and 3.73 rear end. yes it is just the wife and I. Good Luck
