Koopgal
Sep 17, 2013Explorer
Heavy half pickup
We are going to retire in 8-10 months and become fivers and would like to know if the half ton/ lite series 5th wheel with gvwr's of around 10,000 are truly towable by a half ton pickup?
Doug
Doug
mileshuff wrote:jus2shy wrote:
For Ford, the Ecoboost is the tow monster to have. A 10k 5th is really nothing to a modern gas motor until you get above 4 or 5,000 feet.
Currently the ONLY gasser in a 1/2 ton with enough power for a large trailer is Fords 6.2L. All others are far too weak. But that 6.2L is a $3500 add on to an already expensive truck. It makes no sense to spend that kind of money on a gasser 1/2 ton when you can get a diesel 3/4 ton.
We'll have to disagree that a gasser 1/2 ton is fine for 10K under 5,000 feet. The 6.2L's cost is not a good value and you still end up with a 1/2 ton.
JIMNLIN wrote:
No posts doesn't determine the 1/2 ton truck specs on how much weight it can carry and how much it can pull.
There are 1/2 ton trucks out here that can tow a 10k 5th wheel trailer. Their going to be slow on the road pulling 10k so you may not like the hassle.
The used '00-'06 1500HD GM 6.0 engine 4l80E tranny and has a 8600 GVWR with 6084 RAWR E tires and wheels with a 3000+ payload and over a 10k tow rating.
And the used 1500 Mega Cab Dodge trucks have a 8510 GVWR with 6000 RAWR Hemi 3.92 gears E tires and wheels. This truck sits on the 2500 frame and has the same brake system.
Personally I would be looking for a 3/4 ton truck.
If used look at the 8.1 GM gas engine or Fords V10 engine in the used trucks as they don't make those towing beasts gas hogs anymore OR...
A new or used diesel. If used beware Fords 6.0 diesel engine.
It's seldom the engine that's the problem with towing now a days
It certainly is the problem when talking about 1/2 ton trucks and a 10,000 lb fifth wheel.
The F150 does offer a 6.2L gasser thats certainly strong but it's a $3500 add on to an already upper end expensive 1/2 ton truck. Might as well opt for a 3/4 ton diesel and be done.
Dodge offers the 5.7L Hemi. Way to weak for such a 5th.
GM offers the 5.3L, again way to weak.
Shadow_Grey wrote:
Yea, it just cannot be done...you will need at least a 1 ton truck.
Hoppypoppy wrote:CKNSLS wrote:
To the OP-
You will never have anyone on this forum OK a half-ton for ANY TOWING NEEDS.
File it under "it's not gonna happen!"
I towed my boat with one. Zero problems.
