Koopgal
Sep 17, 2013Explorer
Heavy half pickup
We are going to retire in 8-10 months and become fivers and would like to know if the half ton/ lite series 5th wheel with gvwr's of around 10,000 are truly towable by a half ton pickup?
Doug
Doug
tomkaren13 wrote:2oldman wrote:
If the sticker on your truck says you can tow it, then you can tow it.
But do you want to? We just got rid of a 24.5 ft lite 5 er. Our 1/2 ton was not happy towing it. Even read it could haul 8500. Wrong!
therink wrote:
Have you recently driven a 2011+ 3/4 or 1 ton SRW GM? Best riding daily driver truck I've ever had.
valhalla360 wrote:
Lots of circular arguments and chest pounding but more importantly:
Why?
The cost difference is minimal to move up to a 3/4 or 1 ton. Or are you saying you already have the 1/2 ton? (in which case give us the details and it's pretty easy to tell what the ratings are)
Diesel vs gas is a bit more complicated (and mildly religeous). Unless you are going to be doing a ton of miles or always in steep mountain terrain, one of the large gas engines will provide plenty of pull at a much lower up front cost. It's mostly a cost analysis at that point.
CKNSLS wrote:B.O. Plenty wrote:bad99ram wrote:Nonsense! Has never happened and never will. Another myth. Call your insurance company an find out the truth. Insurance will pay but they may or may not drop you after they settle..
Also, if you're just a few lbs overweight and you get in an accident (regardless of who was at fault) and the insurance party finds out you can kiss your retirement dreams goodbye. I mention this because I seen it happen. Very sad.
Please share Specific example
B.O.
Insurance would probably cover it but not the civil suit that would follow if someone was hurt or killed.
goducks10 wrote:orlandimal wrote:
There is no F150 with a 3000 lb cargo rating. The highest rating is approximatly 2300 lb special order F150 with 7 lug nut wheels. I have never actually seen one.
Ford lists the F150 4x2 reg cab with 5.0 as 3120lbs and the 3.5 as 3100lbs. I would imagine an XL in those configurations would be a lot closer to 3000lbs than 2300lbs. Most everyone that orders an HD package in an F150 4x4 whether SC or CC has 2300lbs+/-. So a reg cab 4x2 would be even more.
