machunt's avatar
machunt
height adjustment
i have a curt 5th wheel hitch and ive already made adjustments to it. while on vacation i had a couple occasions where the bottom of my 5ver bottomed out against the bed of my truck. how can i increase the didtance between my 5th wheel and rails of my truck, without getting everthing else out of whack?
  • as mentioned in other post 2011 outback, 2013 chevy 1 ton dually. ive only had issues on this trip. i am only looking for a couple inches. and yes trailer sits very level as is. not really wanting to get into axle flipping and all that
  • Me Again wrote:
    Cummins12V98 wrote:
    Need more info!
    One option is lower pin box.
    A little poking around shows he has a dually(newer?) with LT235/80R17 tires and an Outback 5th wheel 2011. So a subframe lift would be good route to go, as he most likely does not need the full 5.5-6" that "flipping" the axles creates.
    When I raised my Cardinal I had Smiley's flip the axles and lower the jack plates for a 3.5" increase. the old spring perches made a great jacking spots on the axles.
    To bad axles do not come with perches welded on both top and bottom of axles. Of course they would need a "This side up labels"!
    Chris
    Why =any= mfr in the past decade would build FWs without "flipped" axles from the factory, is beyond me. :h
    Lyle
  • With out proper info we are all ASSuming.
    Sure we can poke around to try to find more info but why should WE?
  • enblethen wrote:
    Is the trailer sitting level when loaded for the road?
    What pin box is the trailer equipped with?
    Waht hitch is installed on the truck?
    How much des the truck sink when trailer is connected and loaded for the road?
    He said "without getting everthing else out of whack?" Which I assume means that he has it level now, without enough clearance.
  • Cummins12V98 wrote:
    Need more info!
  • Is the trailer sitting level when loaded for the road?
    Need more info!
    Chris
    Really would be helpful to know what truck and trailer you have, first off.
    Simple things: "flip" the axles (put the springs on top of the axle tube) if not already done; if there are adjustment holes on the spring hangers, make sure you're in the lowest hole. If your truck is fairly recent, there may be factory spacer blocks that can be removed to lower it. If your truck is as low as you can get it (easily) and the FW's as high as you can (easily) get it, and you're still not happy with the spacing, then the only real solution is to add a sub-frame between the springs and the FW frame to get you where you need. You used to be able to gain 2" by adding a CorrectTrack alignment system, but that's been discontinued.
    Rule of thumb is 6", minimum, bed rail clearance while maintaining the FW level. 2-3" nose high won't really hurt much, IMO, other than (possibly) ride, so if you need it, don't be afraid to raise the hitch or lower the pin box a hole.
    Lyle
  • Put springs on top of axles if not already done that is what I had to do
