NC_Hauler
Mar 26, 2014Explorer
Agree with Chris and JIMNLIN on this also....an E rated LT tire should work for you. I had a Coachmen with a GVW of 14,500# and used Michelin XPS RIBS on it and never had an issue.
You state GVWR of 13,990#, or something to that effect, but later on you state you may be heavier:h..I'd want to know the actual GVW of my 5er....I also believe, if 5er's GVW is 13,990# as you stated, putting a 17.5" wheel and tire on, or even a G rated tire on is over kill.
As stated by the above two..purchase one of the recommended better LT E rated tires and unless something is going on with your axles being out of alignment, you should be good to go.
About Fifth Wheel Group
