agesilaus
Nov 22, 2015Explorer III
If you want to continue off the grid then you should look at a solar panel setup. With those and some extra batteries a lot of people manage to get by. It requires power management on your part, thinking about how much power a utensil requires and so on. Switching to all LED lighting helps with that since it greatly reduces the load from lights.
My wife is the same and just prefers to use the CG washer and drier. You would definitely only be able to run those on shore power.
The other thing you have to think about is water and wastewater control if you plan to stay off grid for weeks at a time. People use these wastewater totes assuming there is a dump near by.
Amazon
Hauling drinking water is a different issue, if there is a faucet semiclose to your campsite you may be able to use a water thief to get water to your camper, it lets you connect to one of those faucets without threads:
Amazon
Otherwise you'll have to get some containers and a pump to move water into your tank. I've heard of people using a 55 gal drum but I don't think I'd want to haul one around with me, multiple 5 gallon containers would probably work.
Amazon
Those are collapsable and won't take up a lot of room.
Amazon
Amazon
Amazon
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
