Peg_Leg
Nov 19, 2015Explorer
12k is going to be right at the limit of properly equipped 3/4's. You'll be in the 2500 lb pin range. For a gasser you'll need 4.10 gears. Rear axle weight for some trucks are more fluid than mud. You'll need to research any prospect based on individual specs. Watch out for the grocery getter trucks, big tires and high rear end ratios.
You may have to expand your search area and travel a bit to find your dream truck. It's out there just don't rush into a marginal truck. You seem to be gathering the info to help make a good decision. Explain to Momma that you both may have to compromise for safety of the family.
Good luck.
Good luck.
About Fifth Wheel Group
