River_Sand
Nov 01, 2013Explorer
Although I don't own an FS, WW fridge installs should be close to the same. I removed my fridge to install wires in the vent and the control box for a Sat. dish. Mine had six screws around the front, open the doors and you will see the some of the screws. Then pop off the top fascia and 2 more screw will be visible. In the back remove two more screws that hold it down. You may have to remove the flame shrouding update if you had it done. Unhook the power wires and the gas line and then it will slide out. I put mine on a moving dolly and wheeled to the back of the trailer to clean it up somewhat. While you're in there WW didn't use the best insulation so I redid that too. I think it took me aobut a 1/2 hour it get it out. It's not real heavy just bulky and awkward to handle.
About Fifth Wheel Group
19,040 PostsLatest Activity: May 25, 2026
