WhitehouseLV
Dec 18, 2013Nomad
Is your slide hydraulic? Hydraulic fluid doesn't work well in cold weather.
I had a bedroom slide that the glue on the moisture barrier (black plastic) failed dropping the plastic down & binding up but that was pretty noticeable.
Also had my main slide would go out fine but coming in would stop. Replaced circuit breaker with larger one & never had a problem.
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
