BarneyS
Feb 16, 2023Nomad
I would try turning both red and blue handles 180 degrees and see what happens. Wouldn't be the first time the manual was wrong.
It might be that the blue handle should be left as is and just turn the green one. I would try both ways and see what goes on.
Edit: On further thought, most water and gas handles are on when they are in line with the pipe and off when they are positioned 90 deg from the run of the pipe. I would turn the green handle so it points down (off) and leave the blue handle as it is (on) until the fresh water tank is full and then turn it down (off). In other words, I would fool around with the position of the handles until it works the way it should.
If you are wanting to connect long time to the hydrant, then both should be in the off position and the line from your water pump to the trailer pipes should be open. You would not have a hose connected to the top inlet - only the city water inlet (white hose at bottom right) At least this is the way it has worked in every trailer I have owned.:)
Barney
Barney
About Fifth Wheel Group
