bertschb wrote:
I just ordered a new Grand Design Reflection 318RST 5th wheel (GVWR 13,995) and plan to buy a 2016 GMC 3500 Duramax truck next. The truck has a 6.5' bed.
I've spent a week reading up on hitches on multiple forums and I've narrowed my choice of hitches to the B&W Companion and Trailer Saver BD3 Air-Ride.
My needs:
I want the hitch to be completely removed from the bed when not in use (nothing at all showing).
It has to be something I can lift out myself without a hoist.
It needs to provide a smooth ride that protects the truck and 5th wheel.
Is there a factory under bed hitch mount option I should order with my truck that will make installing the hitch easier or can I get everything I need from the hitch manufacturers? I guess I'll throw in one more question while I'm at it...Can I get the best of both worlds by replacing the pin box on the 5th wheel with a Trail-Air and then getting the B&W Companion which appears to be lighter for removing from the bed?
Kind of overwhelmed with all the options available. Money is no object which helps. Any help would be appreciated!
I'm a B&W "fanboy", according to some, and have no hesitation on recommending them. You can get a factory-prep for a FW hitch on the GM, which leaves you with a clean bed when it's removed without the necessity of adding the Turnover Ball GN hitch to secure the Companion. I use both the GN and FW hitches and love the clean bed when not in use.
Lyle
