gwcamp wrote:
Hi all would like to know if a trail air pin box would work with Anderson set up. Thanks GW.
According to Andersen, they have users reporting back favorable results using the Trail Air. One thing to be aware of is the height of your truck bed. In my case, the 2015 GMC is so high that adding the Trail Air would mean my 5er would be an inch or two off level. Lowering the hitch (Andersen or others) isn't a solution because the 5er would be to close to the bed rails.
A solution that does work well in cases like this is the Reese 5th Airborne whose shock and airbag are internal and it does not add the extra height that the Trail Airs do.
