bertschb's avatar
bertschb
Help with hitch decision
I just ordered a new Grand Design Reflection 318RST 5th wheel (GVWR 13,995) and plan to buy a 2016 GMC 3500 Duramax truck next. The truck has a 6.5' bed.
I've spent a week reading up on hitches on multiple forums and I've narrowed my choice of hitches to the B&W Companion and Trailer Saver BD3 Air-Ride.
My needs:
I want the hitch to be completely removed from the bed when not in use (nothing at all showing).
It has to be something I can lift out myself without a hoist.
It needs to provide a smooth ride that protects the truck and 5th wheel.
Is there a factory under bed hitch mount option I should order with my truck that will make installing the hitch easier or can I get everything I need from the hitch manufacturers? I guess I'll throw in one more question while I'm at it...Can I get the best of both worlds by replacing the pin box on the 5th wheel with a Trail-Air and then getting the B&W Companion which appears to be lighter for removing from the bed?
Kind of overwhelmed with all the options available. Money is no object which helps. Any help would be appreciated!
