ricatic
Aug 16, 2014Explorer
newman fulltimer wrote:
if pressure is building up in the tank your vent line is plugged or pinched take your fill cap off see if it works then.You have to have air behind water
Thanks...but BTDT as well...cap to fresh water tank is off and the vent also work...you can hear the air, not a lot but it vets...when filling the tank from "city water" the fill hose I use mostly fills the inlet opening and the vent works perfectly...
Regards
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
