laknox
Aug 18, 2014Nomad
ricatic wrote:
well...problem is diagnosed...I noticed the underbelly coreplast was sagging a bit directly under the grey water tank...I used a bottle jack and some plywood to raise the sagged area back up to near level...went inside and turned on the kitchen faucett...normal pressure and flow rate at the kitchen sink...they will pump my tanks tomorrow morning so I will be removing coreplast and seeing what failed and allowed the tank to move...certified welders onsite and lots of steel tube and angle...should be able to fix it permanently over the next few days...
Thanks to all who contributed...
Regards
And no thanks to the jokers who designed and/or built the FW in such a way that 1) the tank could sag, 2) the water line runs =under= the tank. Glad you were able to diagnose it. FWIW, the 'plast on my FW is all held on my self-tapping screws, so have a couple batteries for your cordless drill charged up, and start unscrewing. :-)
Lyle
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
