ricatic's avatar
ricatic
Help with water supply issue from fresh water tank
I posted this on the Heartland Forum but thought i would also pick the brains of the members here:
Well...after 5 years and hundreds of nights spent in our 3055RL, my first real issue. I am working in Iowa and staying in a RV Park(loose definition at best) behind the Casino. No city water hookup but I run 200 feet of hose to a fresh water fill hydrant. I have been here for three months. The last two times my tank has ran dry while using the shower, I have refilled the fresh water tank and then experienced difficulties drawing water from the tank. I have bypassed the winterizing valve(whole other story that ends in "dumb owner mistake) so I can easily separate the suctuion line from the pump to the tank in an area where I can either put pressure into the tank or siphon water up to the pump.
Now, the first time this happened, I hooked up the city water hose to a Rube Goldberg connection that allowed me to back flush the line into the tank. Even after this attempt, flow only increased a small amount but was enought o operate the system at full water pump pressure...all was well... this time, using compressed air, I pressurized the suction line until it began bubbling out the air vent. Success I think..wrong again...I still can not siphon any real quantity of water to the pump...
So...I fill my 5 gallon water jug, run the suction line into the container, turn on the pump and voila...normal water volume and pressure at all faucets...
So...how is the suction line plumbed into the fresh water tank? Is there a weight or check valve at the end that might be mostly plugged? Should I be able siphon water up to the pump easily? Any suggestions on how to fix this before my head collapses from trying to siphon water up from the tank...
Regards
Rick
  • if pressure is building up in the tank your vent line is plugged or pinched take your fill cap off see if it works then.You have to have air behind water
  • newman fulltimer wrote:
    take air and back blow into the tank through the suction line see if it blows freely into the tank
    Thanks...but BTDT...see paragraph 3 of my post...it does put some pressure into the tank but it is still very hard to siphon any water up the suction line...
    Regards
    That was my thought too but was beat to it by a few minutes.
  • take air and back blow into the tank through the suction line see if it blows freely into the tank
