SH
Aug 20, 2014Explorer
Hercules Tires
OK...why isn't the Hercules H901 a viable alternative to the GY 614? They are made by Cooper in Ohio, rated G with a load factor of 3756 lb. Truthfully, I have never heard of Hercules but a lot of...
wantabe351 wrote:
On the Hercules tire..or any tire there is the load/speed in the service index ID..its after the tire size on most tires..for the "Power STR" its 128/124L..the L is the speed rating, and on the chart its 75mph...But if you go to the company web site and look up the ST tires and other types of road tires the have...After reaserching for replacement tires or a new rim/tire combo...decided to give the Power STR a try..For it has a capacity of 3920lbs for each tire....used Hercules in the past and worked well..after 3 failed GY it was time for a change...
