steiny93
Jul 01, 2015Explorer
justinleebuckley wrote:
Thanks for all the help. It wouldnt be strange but i used one AC all this month instead of 2 like last month and the bills were 6 dollars apart. I have a 38ft 2007 select suite. My neightbor has a brand new sierra. My other neighbor has a high end heartland.
1 or 2 units doesn't really matter if a single can cool it to the same temp
do this
1) Verify you are the only consumer off the meter (stuff can be wired weird). When its really hot out; go to the meter when your rig is unplugged; see if its spinning. It shouldn't be turning
2) Plug in the rv; without the ac/water heat/etc turned on you should see a small usage being registered.
3) Take a measurement of the amp draw of your ac units or find the manufacturer tags and see if their run times jive with the kilowatts being used. Example: if they never shut off and they draw 40amp continuous the $'s make sense.
my guess,
your rv has ac units that are using more power and they are running more due to less insulation vs. your neighbors newer rigs
About Fifth Wheel Group
