sayoung's avatar
sayoung
Hitch capacity
My friend is needing a favor from me.my Reese hitch is a 16k and he is needing a grand design brand momentum toy hauler moved from San Angelo to gilmer.the specs say it has a 18k+ GVWR but it has only (2) 8000lb axles.
My truck is plenty enough able but I have a great reluctance since my hitch is only rated for 16k.i told him he might just need a delivery service.his son lives in this one and a deal or delivered to the present spot.
Anybody towing one of theseand if so what hitch.safety 1st.
  • Golden_HVAC wrote:
    Hi,
    It is 18,000 GVWR, but the overall trailer weight should be less than the GVWR.
    Do not load it up, and it should be well under 16,000 pounds 'empty'.
    Fred.
    I like this answer
  • If it was a couple of miles from one spot to the other I would do it
    BUT Gilmer is 347 miles from San Antonio.
    No way!!!
    Have your friend contact an RV transport company or find someone else with a 20K or higher rated hitch
  • Well and good for an empty rig ---- But if you read the post, his friend's son LIVES in it.
    Art.
  • I would do my friend that favor, an unloaded Momentum will not be 16K. Help them out, they will owe you a favor.
  • Grand Design shows a 13,800# dry and 18,000 GVWR.
    Vehicle weight is pin weight plus axle weights. Your hitch should be rated in excess of the actual towed vehicle's weight.
    Your 16,000# hitch should work if they have not loaded the trailer past 16,000#. A trip to the scales would be in order. We added around 1,500# to ours so if someone has been living in it, you probably need a larger hitch.
    The scale will answer your question.
  • Hi,
    Fred.
  • Time for a new hitch. Curt 24k would be a great choice.
    Thanks!
    Jeremiah
  • It is like playing the lottery, sometimes you win, sometimes you loose.
    Which do you think you will get?
    It depends on which Momentum also. The smallest has a GVW of 18,000lbs, the other 2 are 19,500LBS gvw.
