bobbyg123
Aug 01, 2019Explorer
Hitch choice
Hi everyone. I own a 2017 F350 6.2L long bed crew cab, and I’m in the market for my first 5th wheel hitch after 10+ years of bumper pulling. I’ve heard good things about B&W, but they of course ma...
dryfly wrote:Big1 wrote:MFL wrote:bobbyg123 wrote:
Well, we settled on a B&W Patriot 16,000 non-slider.
Good price, good reviews. Having never used a 5th wheel hitch before, I have no idea how good it is, but it seems to have a good reputation. I'll be pulling a 5th wheel with GVWR under 10,500lbs.
Thanks.
Congrats on your new Patriot!! IMO, from actual use, the best rail hitch available for the dollars spent. You will be very happy with that hitch!!
Jerry
Congrats! It's a good hitch for sure this is the one I have.
In this photo I can see the jaws are definitely around the pin, and the pin box is flat on the hitch head. It's very obvious!
Please....I don't want to create controversy, but I'm curious about the term "high hitch". I assume that's when the flange on the bottom of the pin is set down on the top of the jaws of the hitch.
If that's the case, couldn't that situation be detected by a visual inspection of the jaws? I've been pulling a 5th wheel for years and I've never had that occur once. Seems like one would immediately see space between the pin box and the hitch head. And if it's determined that the pin is correctly in the jaws and is locked in place, I would thank that would minimize the need for a pull test.
Again, I've seen the need for a pull test argued many times on this forum, and I'm not trying to incite that. Just trying to find the way(s) that dropping the trailer is possible.
