memtb
Jan 03, 2018Explorer
steveksfc wrote:
Can you mount the hitch behind the rear axle? Yes, Should you? I wouldn't if it was me. Would I have the bed shortened? Yes I would. I have seen several that the rear wheels were close to the rear of the bed. In fact some actually mount the hitch a few inches ahead of the axle. My first question is "What is the total length of the hitch box? You can install a longer hitch box on the 5th wheel. What was the truck used for before?
As stated by others.... it can be done. With your truck and the light trailer...no problem. Though again as stated....it “will” tow a bit like a tow behind. I also would shorten the deck!
This was all repeated, to get this point. if you choose to go with a larger, heavier 5er, you have rendered your set-up a real “tow” liability. Most folks who start out small, light... quickly go larger. Greater pin weight with this set-up....would put you in a place you don’t wash to be!
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 19, 2026
