laknox
Jan 03, 2018Nomad
S.Parker wrote:steveksfc wrote:
Can you mount the hitch behind the rear axle? Yes, Should you? I wouldn't if it was me. Would I have the bed shortened? Yes I would. I have seen several that the rear wheels were close to the rear of the bed. In fact some actually mount the hitch a few inches ahead of the axle. My first question is "What is the total length of the hitch box? You can install a longer hitch box on the 5th wheel. What was the truck used for before?
Hitch box is straight up and down. I've seen the kingpin extenders. But from what I think puts extra stress on different part of the frame in a way it might not of been ment for. Kinda of abandoned that thought a while back.maybe I'm wrong
Most FWs are built with an extended pin box in mind, whether one is used, or not. Personally, I wouldn't at all be afraid to replace the pin box with one that will give you the clearance to have the pin over or 1-2" ahead of the axle centerline.
Lyle
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 19, 2026
