eHoefler wrote:
4x4ord wrote:
In my case hanging 900lbs 35 inches behind the rear bumper will remove 694 lbs from the pin. Until I try it I really can't say how it will affect the handling of the trailer. There will still be 17-1800 lbs on the pin.....5300lbs on the rear truck tires so my guess is it will handle fine.
Do you have he available room in the capacity of your axles to add 1500-1600 pounds to them??
The trailer has two Dexter 8000 lb axles with disc brakes. Tires are g rated with a weight rating over 4000lbs each. Citation rates the axles at 14000 lbs so I guess the springs are the week link. Currently the unit has an axle weight of 11500 with most stuff loaded....no groceries or water. So I think it has room. Worst case scenario I'd have to upgrade the springs.
