breeno wrote:
Thats_Ok wrote:
Are you towing with the truck in your signature?
Frankly I don't recall seeing a Tundra pulling a fifth wheel.
Haha, heellllllllll no.
Current plan is a 2011+ F350 DRW. (5er we are interested in is ~15k GVWR)
I see there's an OEM 5th wheel prep option for this truck, anyone know if this is worth it?
IIRC there was an OEM version of the B&W that will work with this prep...
the 5th prep.. if you want under the bed, then you gotta do something. this is as good as anything else. but it can limit your hitch choices..
Reese and B&W both make hitches that fit the prep.. I've seen one guy add the prep after delivery.. usually u gotta get it from the factory.
ford 5th wheel prep kitthe B&W OEM is
hereand you can do the B&W turnoverball underbed, and the B&W Companion for roughly the same price, and get the same function too.
