bad99ram
Aug 25, 2013Explorer
When you unwinterize you should also sanitize your water system. The easiest way is to add 1/4 cup of bleach to each gal of water. Pump it into you lines the same way as you add antifreeze. Make sure you can smell bleach at each faucet. Let sit for 4hrs then flush your system with fresh water. That will get rid of the odor that the Pink stuff leaves.
About Fifth Wheel Group
