chops1sc
Nov 01, 2016Explorer II
I used Belltech lowering shackles to lower mine about 1.5". All they do is change the location of the rear leaf spring's mounting point. None of the actual suspension is affected. There is a point where the bump stop can come into play. If you regularly haul heavy loads in the bed I would not recommend lowering it. You can also get smaller lift blocks for the axles. Dodges and Rams are a different animal since they don't have leaf springs.
Belltech.com
Belltech.com
About Fifth Wheel Group
19,030 PostsLatest Activity: Dec 13, 2025
