laknox wrote:
korbe wrote:
bulletbob007 wrote:
.............I'm looking at the rear area between bumper and rear axle...........
I would be cautious of using that area since the clear area is often needed when entering driveways or elevation changes.
Why? Every tote I've ever seen is =much= shorter than the bed rails. Only if you had a massive, shock-absorbing pin box might this even come close to being a problem. In that case, you'd likely have more issues with the pin box hitting the sides of the bed than the tote.
Lyle
I thought the OP was describing the underside rear area of his 5er, not his truck bed.
