rehless wrote:
I have the same water heater in a 2012 Montana Mountaineer. The electric side was **** from day one. Had it repaired three times in first year or two. After last repair I have not tried the electric side, use the propane side only.
I would prefer an Atwood.
WHY?
Atwood uses same set of t-stats for both gas/electric so if you have a problem with them or the circuit neither electric or gas will work.
Have had both...each has pros/cons but really are basically the same.
They heat water and are fairly basic.
What was needed to repair your Suburban electric 3X?
