beetleman wrote:
Yes, everything else works. Her hot water switch as a reset light. If she runs her finger along the reset light it will comes on. It is not a button. But if she touches it light will come on or go off. Wondering about a short.
That light may be normal and may be for the gas portion of the heating.
A short will trip a breaker, cycle the breakers off and on, then retest. If the water was off, perhaps the water heater was not full and that will smoke a heating element in seconds. Bring a meter and check for voltage at the element, if voltage is present then replace the element, available at most hardware stores. A cheap tool is also available for changing elements.
If you have no success, come back with the make and model,
