One thing to be careful of here is if the house wiring is very old the ground might be "floating" I think they call it? This allows a portion of the 120 volts to pass directly to earth without going back on the neutral leg. I've read a lot about shock injuries on RV's because of this but don't know if there's anything to be done about it because they use the RV skin as a ground. If I take a voltmeter from the skin of my RV to earth I read about 65 volts, not enough to hurt you but enough to get your attention. I read about it at RV Doctor, Google it, I'm sure you'll find it. My house was built in the 40's with cloth romex and no ground and from what I've read, and my son the electrician, there's not much I can do about it so I just unplug it whenever I'm working on the chassis or something where I'm grounded.
