dave46
Oct 29, 2015Explorer
House hookup
I have a Fuzion Chrome toy hauler what do I need to hookup to my house. I have a four prong plug so I need a 50amp breaker. What type wall socket and romex?
Thanks
Dave46
Thanks
Dave46
paulcardoza wrote:
Every one of these home power plug threads turns into a s**t show! The OP needs to print out the diagrams and instructions from the links posted at the top of the thread, hand it to their electrician and make 100% certain he reads it.
Make sure they are crystal clear they are not installing a 240V clothes dryer plug!
Old-Biscuit wrote:joebedford wrote:
30A = hot, neutral & ground. I suppose if you put the neutral on the other phase you could get 240V but why would anyone do that? Put a double-pole breaker in instead of a single pole? I guess if you're paying your 'electrician' with beer, don't pay until the job is done.
Correct JOE
A 30A RV servce is one hot, one neutral, one ground 120V AC
Unfortunately many 30A services are used for 240V AC welders, dryers, electric ranges in the residential world. One that most electricians are familiar with.
So when contracted to wire a 30A service they naturally think 240AC
Two hots and one neutral.
Same number of wires but wrong hooked up for an RV service.
That is where you and the electricians get confused...assuming they know what they do.
Where as 50A is 4 wires ALWAYS
Anyone having a 30A RV service installation should always confirm with a meter that it is wired 120V AC vs 240V AC
Old-Biscuit wrote:joebedford wrote:Mandalay Parr wrote:30A is easy. Definitely get a real electrician for 50A.
If you decide on either a 30 or 50 amp, I strongly suggest to hire an electrician to do it properly and to code.
30A is where everybody screws up and wires it 240V....even the 'real' electricians
