schlep1967 wrote:
If the manufacturer had put the front axle behind the back axle, you would not have this problem.
This is most likely a classic example of the salesman telling the design guy what the customers are looking at. High published empty pin weight makes smaller truck owner move away from these trailers. So they design them to shift the weight back when empty. That works fine, unless you use the same frame on a toy hauler where you add 1,000 or more to the rear. And now you have the OP's problem.
Looks like you would have to travel with no water or fuel until you get close to your destination. Or maybe empty water tanks and water jugs up front to help offset the weight of the SxS in the rear.
It's only an 11' garage (10.5' usable) so you aren't putting a lot of vehicle in the garage anyways.
I would also argue that a lot of this was my own doing with the options. I got the 3rd AC in back (100 lbs), the glass doors instead of pulldown screen (80-100lbs), power awning on the rear (80?) extra side awning (80?), slide toppers (minimal and not any behind the axle). So that's at least 350lbs of "stuff" I added to the rear of the camper which is obviously taking away some CCC in the garage.
I don't need to travel with 75 gallons (or full 115gal) of water either. I just always filled my tank on the old camper so I do it out of habit.
Also, I can re-arrange stuff as well. Right now I have light stuff like the camper chairs under the front bed, which is the most forward storage I have. I can put my spare tire up there, or both spares (I ordered an extra that stayed in the garage), my tools, spare parts, etc. that I seldom use are in the passthru storage which can be moved to the bunk storage. I have a table top on the rear hapijack that is for the garage, but we have not used it once. I can pull that out and save 25 lbs off the rear. The table for the sofa was too big the one time we used it, so I bought a little side table. Another 20lbs.
Other stuff we don't need can come out of the camper. Extra pots/pans, cups, electric griddle, etc. All this little stuff will add up. If I can, I will get this all done in time for Friday. I will then re-weigh with the cycle to see how the weight moved around.
