This was the result of rearranging weight around in the camper and removing approximately 100 lbs of stuff not needed, as well as 80 lbs of fuel from the fuel cell (10 gallons worth).Had the same 80 gallons of fresh and cycle as last time.
Removed 320# off the trailer axles.
Put roughly 300 lbs back on the pin.
Putting 1500 lbs of water & cycle now only removes 10% of that weight, 150lbs, from the pin vs 500 previously.
Steer axle went up since I weighed with the wife and dog this time.
I would the results are positive and pretty much what I figured. The heaviest items- Spare tire, grill, fuel all removed from the very back of the trailer and put towards the front helped quite a bit. As well as some of the other items such as tools and a 40 lb wagon.
With that being said, I am going to look into upgrading the axles and brakes over the winter to 8K lb just for the peace of mind.
