golf_bears
Jan 09, 2016Explorer
Any one of those trucks will pull those RVs. That is not the problem. The real issues to be concerned about are:
1--- Will the TV rear axle carry the load? What's the TV rear axle rating.
2--- Will the TV tires carry the load? What are they rated for?
3--- Will the truck stop the load?
As suggested, you can change the gear ratio and/or go to a dually.
Personally, I would get a dually with at least a 4.1 gear ratio.
Like many RVers, you get a TV with more capacity than you need to start with because down the road Ma-Ma most likely will want a bigger RV.
As your user name implies, "hopeisnotastrategy", get it right the first time!!!!
About Fifth Wheel Group
