- Mortimer_BrewstExplorer II
Old-Biscuit wrote:
I have a gen for boondocking BUT it is NOT installed in 5th wheel
My 4kw gen is in forward area of my long bed truck in its own enclosed gen box that has its own fuel tank and is insulated. Plus air intake and exhaust are designed to provide sufficient cooling air, air for combustion and quiet exhaust
Old-Biscuit, do you have some pics of the generator setup in your truck bed? I’m curious to see what it looks like. - pcm1959Explorer II
greende wrote:
I use a portable because I can use it when I lose power at the house or need power away from my electric service etc. For me it is about versatility for the money spent.....
X2 - greendeExplorer III use a portable because I can use it when I lose power at the house or need power away from my electric service etc. For me it is about versatility for the money spent.....
- Ralph_CramdenExplorer II
Blanco1 wrote:
newman fulltimer wrote:
solar charger big battery bank inverter whalla
How long will this run an A/C & microwave?
Depends. How big is the battery bank? Is it 100% overcast and raining for a week or clear? Are you in the woods under the trees where hardly a spec of sunlight gets through, or an open field? Depends. - wanderingaimlesExplorer
352 wrote:
WHAT IS A GENERATOR????
thing in a bottle you rub and make a wish ?
With the most frequent wish being,,,,, that my camper was cooler? - edatlantaExplorer II
Factory 5th wheel gen is in front compartment (under bedroom) or on the roadside basement compartment area (again under bedroom)
No thanks!
Noise, vibration, exhaust.
I have 2 50A twist style receptacles .....OEM rear and an added one forward under overhang.
I can plug gen into either one depending on parking situation OR into front one while in transit so rig is cooled down when we arrive
Manual transfer switching with inter-locked 50A circuit breakers (one one set can be closed at a time.....power only from one receptacle)
Factory option..........not necessary
Course good solar system...panels/batteries and one can also go 'gen-less'
Noise - Can't hear mine
vibration - There isn't enough to feel
exhaust - Genturi when in crowded campgrounds. Never been a problem. - Blanco1Explorer
How long will this run an A/C & microwave? - valhalla360NavigatorIf you boondock a lot, a built in generator makes a lot of sense but if it's just a few times per year or you don't run the air/con, it makes far less sense.
We only boondock occasionally so the portable yamaha in the truck bed does just fine.
Yes, it's theoretically possible to build a solar system that will run the air/con but you can buy, maintain and fuel a generator for a few decades for less cost. - newman_fulltimeExplorer IIsolar charger big battery bank inverter whalla
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
