Y-Guy
Sep 27, 2020Moderator
You will find that adding more to the hauler really doesn't reduce the pin weight as much (if any) as you might expect. I'd suggest taking your setup across a set of scales. The best network of scales is to find the nearest CAT Scale and see for yourself. Taking it loaded and unloaded can be eye opening.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
