camp-n-family wrote:
Actually camp-n-family is right on the mark with TT and TH being like apples and oranges - they are quite different in how they are designed. Traditional trailers are designed to be mostly balanced with approximately 10-12% tongue weight empty. Toy Haulers on the other hand are designed with substantially more tongue weight empty around 20%. They do this on purpose to offset the massive amount of weight that will be placed - often times behind the rear axles of the trailer.
That may not sound like a lot but you can't really tow around a TH properly without the toys in the back to balance out the load. The towing fundamentals stay the same with optimal towing around 13-15% tongue weight. Toy Haulers are more complicated to tow and balance properly and it requires a bit of forethought to place cargo appropriately.
I'm not familiar with the TH mentioned but if delivered weights are close to the listed dry weights, 4k with a tongue of 450lbs (11%), it could easily be loaded to maintain proper balance and tongue weight. For example if it is loaded with 500lbs worth of options and 2k worth of stuff would put it around 6500lbs loaded. A tongue weight of 15% is under 1k and should be achievable even for a toy hauler.
Hence, this is part of the issue. I am very familiar with toy haulers as I have owned both bumper pulls and 5th wheel toy haulers.
There is no way on this earth that a toy hauler has 450lbs of tongue weight.
No wide body toy hauler, like the one the OP is asking about, will have a loaded tongue weight under 1000lbs.
My FS3000 Weekend Warrior had a listed tongue weight of 900lbs. I bought a tongue weight scale and measured my tongue weight, at the ball.
Empty trailer, no toys, all tanks empty, my tongue weight was 1400lbs.
Full water, no toys, my tongue weight went to 1600lbs.
Full water, toys in the back, my tongue weight went back down to 1400lbs.
My buddies FS2600, 2 axle, was even WORSE!!!!
No toys, no water, tongue weight of 1700lbs.
Full water, not toys, tongue weight went to 2000lbs.
Full water, toys in the back, tongue weight of 1700lbs.
These are real world, actual measured weights. Not some brochure.
