rhagfo
Mar 13, 2016Explorer III
rjxj wrote:
Are the axles flipped? Pull the rig onto some 2x8 and see how much it takes to get it level. The flip can be calculated by adding the radius of the axle + the perch + the spring pack. I installed new sprigs and noticed that they didn't arch as much as some trailers I've owned. Correct track can also provide about 2 inches of lift I believe.
Correct on the Correct Track, it does provide 2" of leveling.
Flipping the axle will provide the diameter of the axle + the spring pack + 2* the perch thickness.
Rjxj, you just forgot adding it back under the spring pack.
It does look like the axles are already on the bottom of the springs.
About Fifth Wheel Group
