johntank
Mar 14, 2016Explorer
rhagfo wrote:
I think a better method would be to measure/calculate the height of the hitch plate from the ground with your 5th wheel attached on a level surface.
Then on the same level surface disconnect the 5er, and level.
Then measure the distance from the bottom of the pin plate to the ground. The difference between the two is how tall sub frame needs to be to tow level.
This is about the best answer that I have seen given to raise a 5er to tow level.
Thanks rhagfo hope I can remember this on my next one.
About Fifth Wheel Group
