shadows4's avatar
Mar 27, 2022
How to increase payload?
I have a 2015 Coachmen 324 TSRK, it has a dismal 1284 lbs of payload. It has 5200 lb axles. It was one of only two models produced by Coachmen that year that 7000 lb axles were not an available option. I know I cannot change the rating on the yellow payload sticker. But what would be the harm in changing the axles, springs, brakes with 7000 lb axles, springs and brakes? Would I be safely increasing my payload? What about just changing the bearings to 6000 lb bearings? It it my understanding the only difference between the 5200 and 6000 lb axles is the outer bearing? Thanks in advance.
  • I would worry about the frame and that would be my guess that they didn’t offer 7000 pound axles. Can you see the frame in one of the units that had 7000 pound axles to see how much difference there is?
    I love to modify and make things better but I’ve had entry level RVs that weren’t even sturdy enough to handle the original manufactures ratings … they flexed so much and broke apart without even overloading them. Craig
  • Swapping in new axle assemblies (hub to hub including springs and tires) would go a long way towards achieving your goal. I would be concerned that the thickness of the steel in the frame would not be up to the new axle capabilities.
