Thomas_fl's avatar
Thomas_fl
hydralic landing legs fall
Lippert hydralic landing legs keep falling. I have replaced one leg and the cartridge valve and they still fall. Once in a while they will stay up but not often. RV is useless with this problem.
  • He answered his own question...It is Lippert, so do not expect a lot.
    Ken
  • If it is a question looking for ideas - it sounds to be either a seal that is leaking (probably within a Cylinder) or possibly crud in the system causing leaks... The later problem has been known to cause problems that you can spend all day chasing and replacing parts - when the only real solution is to purge the entire system of fluid, clean where possible, cycle new fluid through the system and then drain a second time.
    Hydraulics want to be very clean within the fluid systems.
