rperrymExplorerSep 19, 2015Hydraulic PumpI have read about manually operating the hydraulic pump with a drill and a 1/4" hex bit. There is an opening on the end of the pump to insert the bit. Has anyone ever done this? If so, does it work...Show More
KjacksonExplorerSep 20, 2015I had to do this when my hydraulic motor went bad. Easy to do, the slides move easy and faster if you close the valves and do one slide at a time.
Related ContentWater PumpSuspect hydraulic pump (slides) fadingHurricane - Hydraulic Pump FailureLippert hydraulic pump problemHydraulic slide pump
