wingardc's avatar
wingardc
Hydraulic Pump for slides - 2006 Monaco Executive
Does anyone know how to get to the hydraulic pump, for the slides,located behind the steps in the 2006 Executive, to check the fluid levels. Found the hydraulic pump for the leveling system and checked that. Can see the one for the slides but can't figure out how to get to it - nothing in the manual about checking and/or replacing hydraulic fluid for slide operation.
  • OP, open your top step. You'll see the plastic storage bin. Remove the six screws and lift that bin out. All your stuff is right there. Make sure you clean the top of the reservoir well before removing the cap to check the fluid level. Since it's exposed, lots of junk adheres to the top. You don't want any debris inside that reservoir.
    BTW, attached to that reservoir are the valves that you open to release the slides should one fail....Dennis
  • dougrainer wrote:
    Trackrig wrote:
    dougrainer wrote:
    You do not need to replace the fluid for Leveling or slide systems. "Some" Monaco's had a removable step panel for accessing that pump reservoir. Others, you had to crawl underneath and use a mirror and flashlight to see the level. But, unless you have had a leak, there is no way for the fluid to go away. Doug
    I'll agree with you in theory, but. On my 2005 Fleetwood Excursion 39S, after using it for two years, the leveling jack alarm starting going off a lot while going down the road and the panel would say a jack was still down.
    I stopped to check them many times and crawled under the MH more than once. All of the jacks were up where they belonged. Never found any leaks nor any drips on the ground.
    I also checked the reservoir level and it was fine. Still the alarm would go off each trip. So finally I added a little bit of fluid to the reservoir - the alarms stopped and haven't come back.
    The OP isn't having any problems, but he should know how to check the slide pump, how to fill it and have a quart of whatever fluid it uses with him.
    Bill
    I stated you did NOT have to replace the fluid, not that you did not have to check it. Both Powergear and RVA jacks systems use a float sensor in the reservoir for jack down indication. It only takes less than a pint to cause the level to be low. Doug
    Did I say anything about replacing the fluid??? I was pointing out that I couldn't find any leaks in my system, but yet I had to add just a little bit of fluid. In my case it maybe 3/4" out of a quart bottle to stop the alarms.
    Bill
    Bill
    Bill
  • Wingardc, do you have a lift storage compartment under the middle entrance step? If so, there are 100 screws (ok, maybe 10-12) to undo the plastic bin so it will lift out. That's how ours was made on the '08 Dynasty and the pump was right in that area.
    Good luck,
    MM.
    Bill
  • You do not need to replace the fluid for Leveling or slide systems. "Some" Monaco's had a removable step panel for accessing that pump reservoir. Others, you had to crawl underneath and use a mirror and flashlight to see the level. But, unless you have had a leak, there is no way for the fluid to go away. Doug
