Doc_Rock's avatar
Doc_Rock
Hydraulic Pump for levelers
I have a 2007 Monaco Cayman 38' and need to replace my hydraulic leveler pump and reservoir. I can not read the model number but I know the system is made by PowerGear. I understand that all pumps are all the same for all models of the 36-40' Monacos. Can anyone please provide me with the part number for the hydraulic pump. THis has bee a nightmare. There no longer any monaco dealers in my area.
Many Thanks,
Bill (Doc Rock)
  • As a follow up to what to what "bullydogs1" satted, you can email Monaco with your coach number, (not your VIN) and they will send you the build sheet for your coach with all the components that were installed in your coach.
  • I have a 2009 Cayman and it has the Lippert 645480 hydraulic power unit. Lippert still sells replacements. You can call Monaco and ask for your RV's build sheet (or data card). It has the manufacturer, model number and serial number for many of the larger components.
  • If you call Monaco support 877 466 6226 with your coach #, they can give you the exact model and such and you can order it from powergear...it may only come as a full piece which my LCI system did and it is virtually the same system.
  • http://www.lci1.com/assets/content/support/manuals/pg-pg--parts-and-service-manual-airhyd.pdf. Some on Amazon also. If motor is bad might take it to a starter shop for rebuild.
