naturist
Jun 16, 2013Nomad II
Glad you found the problem. That a leak here can appear far away, over there, is a lesson from stick and brick construction as well. When you have a leak somewhere, it is unusual for it to appear directly below the actual problem. You must look far and wide for possible sources. And if a fix doesn't do the job, it merely means you need to look even farther afield.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
