Buzzcut1
Jul 11, 2021Nomad II
Glad I caught this
Doing my usual walk around something caught my eye. I noticed one of the bolt heads on my front jack mounting plates was missing ( drivers front corner) I wasn't too worried as there are 5 bolts on that plate and 6 on the other side of the corner. Then I checked closer, not just one bolt head was missing but two others were snapped off but still there stuck on by Dicor.
I figured and hour tops to use an easy out and replace the bolts. Nope try 5 hours. Had to take the jack and mounting plate off as one of the bolts snapped diagonally and I needed better access to drill. OK the Lance is a 2008 1055, aluminum frame.
When I pulled the jack plate I figured out the issue. on one side of the plate no lap sealant, the other side had over 1/8 of an inch of lap sealant. The plate was not flat agaist the camper and over time the flexing of the plate on the sealant caused the grade 5 bolts to crack and fail.
I replaced all the bolts with Grade 8, cleaned up all the old sealant, reapplied a thin even layer dicor and then after remounting the plate I sealed all the bolts and seams with no sag dicor
I did inspect all the bolts on the other jacks and they were all good
It pays to check all your stuff on a regular basis
